Go Back   Automotive Forums Car Chat > Volvo > General Discussion
Old 05-27-2010, 10:17 PM
gm94 gm94 is offline
MAP sensor location
Hi guys. My will stall at idle. I pulled the codes and one was for the MAF and the other for the MAP. I cleaned the MAF sensor with MAF sensor cleaner and the code hasn't showed up anymore. The car drives normally except when it has to be at idle. If you keep the rpms up it wont stall.
I'm trying to look at the location of the MAP sensor. I heard that it is on the black plastic housing on top of the radiator. I know that the Boost sensor is the same as the MAP ( part wise). I also noticed the same sensor on the intake manifold right underneath the fuel rail.
Can someone post a pic or let me know the location? The car is a 2001 S40 turbo. Thanks.
