Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 05-27-2010, 09:35 PM
lonewolf1218 lonewolf1218 is offline
1995 chrysler concorde codes
I have a 1995 chrysler concorde that wont start.No spark.I turned the key on 3 times and i think the code sequence was 35455,what dose that mean?i think I read the codes wrong,i did the sequence again and it came up,12 5455,mdoes that make sense?
Old 05-28-2010, 07:19 AM
jdl jdl is offline
Re: 1995 chrysler concorde codes
Code 54 is loss of cam sensor signal. With hall-effect sensor, I check ref voltage--ground and signal. Code 12 is loss of battery voltage at some point, code 55 is end of message.
Old 05-28-2010, 10:37 AM
so its saying the camshaft sensor is bad?What is hall-effect sensor?
Old 05-28-2010, 10:43 AM
jdl jdl is offline
The computer thinks there is a problem on that circuit. You might check the crank sensor also. Could be the sensor, could be the wiring circuit.
