Old 05-27-2010, 05:50 PM
Firebird1 Firebird1 is offline
Send a message via AIM to Firebird1
Passenger window
Hi again, my passenger window is suck in the down position. Is this the motor, fuse or relay that has reached it life?????? Help please!!!!!!
Old 05-27-2010, 06:43 PM
jdl jdl is offline
Re: Passenger window
I just wanted to double check year--make--model? It's probably the window motor, but, I'd still check wiring circuits.
Old 05-27-2010, 09:18 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Two words.
WINDOW LOCK
Check it.
Old 05-27-2010, 11:30 PM
The car is a 93' 3000GT-VR4, first gen
Old 05-28-2010, 10:10 AM
91STT 91STT is offline
3SNJ Pres
If your driver side works, it is not the relay or the ETACS unit.
As Stealthee has suggested check the window lock button.
When you press the window up and down switch in both directions, do you hear any motor load?
If you do than the switches are probably good but may also suggest high resistance in the contacts of the switch(es).
If not, the possibilities are the driver side switch, passenger side switch, motor or wiring between components.
You will need to remove the passenger door panel to check.
As long as you don't suspect the driver side switch, you do not need to pop the driver side door panel.
You can check the driver side operation from the passenger side.
Check with a voltmeter at the passenger switch (all readings taken from passenger switch assembly) with both switches at rest you should get the following readings:
Green/Yellow = Ground
Blue/Black = +12V
Brown/Yellow = Ground
Green/Red = Ground
Green/Black = Ground
If you operate the passenger window in the up direction from the driver side switch:
Blue/Black = +12V
Brown/Yellow = +12V
Green/Red = +12V
If you operate the passenger window in the down direction from the driver side switch:
Green/Yellow = +12V
Blue/Black = +12V
Green/Red = Ground
Green/Black = +12V
If you don't get ground on any wire, the possibilities are the driver side switch or wiring.
Lack of +12V on Blue/Black would suggest an open in the the wire.
Operating the passenger side switch, up:
Blue/Black = +12V
Green/Red = +12V
Blue/Black = +12V
Green/Red = Ground
Green/Black = +12V
If either or both of the Green/Red or Green/Black wires do not change state when the switch is operated, the passenger switch needs replacing.
Disconnect the plug for the passenger switch and apply +12V to Green/Red and ground to Green/Black.
You window should rise if the motor is good.
If not, your motor is most likely bad.
If you hear motor load when you apply direct power but the window does not go up, check to make sure the regulator is not binding up.
As a last resort, remove the motor, push the window up by hand and reinstall the motor.
This doesn't fix anything but will keep your interior from getting wet in the rain.
You do not have the follow the above in order, I wrote it as it came to me. So you can check the motor first.
Let us know how it goes.
1991 Stealth R/T TT
It looks stock, so it must be.
Old 05-28-2010, 10:56 AM
Red face Re: Passenger window
Thanks guys. I'll try your suggestion. I'll try them.
