Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 05-27-2010, 04:58 AM
basscat348 basscat348 is offline
2005 5.3 fuel pressure question
Truck almost will never start on the first try unless I turn the key on and wait about 5-10 seconds,then it will start.If I try to start on the first time it will just crank over and then the second time it starts the way it should.It sounds like the fuel pressure is bleeding off somewhere and the pump has to build up the pressure again in order to supply the injectors.Any help would be great.
Old 05-27-2010, 01:11 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2005 5.3 fuel pressure question
You need to hook up a fuel pressure gauge and check key on pressure and then engine cranking pressure and watch for fast leak down.
Also jumper fuel pump and see if it goes up to and hold specs.
Make sure engine cranking is up to specs.
Post back fuel pressure readings.
Lot of problem with the 5.3 fuel pressure regulators.
Pull vacuum line and check for gas in it.
MT
Old 05-27-2010, 01:14 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Thats what it sounds like. You can pull the vacuum hose off of the fuel pressure regulator located on the fuel rail. If fuel comes out of the regulator you found your problem.
