Old 05-04-2003, 02:34 PM
postie1686 postie1686 is offline
Send a message via AIM to postie1686
custom sub box?
hi i just got my car and am looking to put a set of 12" subs in it. i was wondering if any knows a place i could get a sub box for my 91 camaro rs?
Old 05-05-2003, 11:53 PM
Ricky87-Z Ricky87-Z is offline
subs
I have an 87 iroc i cut out a plate for the back then set the 12"s in there....it depends how picky you are..havent used them yet but im sure they will work
Old 05-19-2003, 02:23 AM
BullShifter's Avatar
This may sound cheezy but you can actually make a "bass tube" from a concrete form found at any building supply or hardware store. They come in all different lengths/diameters & are made of carboard(light) 1 end has the speaker & the other gets a port or ports & terminals. You want to add some kind of stuffing inside. Its pretty simple & cheap to make. Sits right down in the "trunk" with the amp mounted on top. T-tops still sit the way they were intended not with a speaker pounding against it. Most people think its 2 12's they are hearing & its only a single 10" sub running on 150watts. I have tried this in other makes but the camaros & firebirds sound the best due to the rear glass.
the plate is a cheap way to go or cutting one yourself but if you have t-tops & keep them in the trunk you might crack one from the bass, seen that happen a few times & good t-tops aren't cheap:bandit:
