Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-26-2010, 08:00 PM
Ubes Ubes is offline
Blower woes. Help needed.
I was driving home from work about 3 weeks ago and noticed that the car was a little slower on the get up. Got home and this is what I found under the hood. Idler pulley is missing, along with the SC belt. As I don't have the 450.00 the dealer wants to get the job done I'm gonna try and DIY it.
The piece left on the idler bracket is siezed up (won't move more then a little back and forth).
Any help that can be offered of where to start would be appreciated. I know I need a new belt and pulley, however any advise for this novice is wanted.
Also, if this turns out to be a bigger job than anticipated, will it hurt if I do nothing until I work up funds to get it repaired?
http://img709.imageshack.us/i/picture001fd.jpg/
http://img514.imageshack.us/i/picture003ma.jpg/
http://img718.imageshack.us/i/picture002u.jpg/
2000 Pontiac Bonneville
Thanks in advance!
Old 05-27-2010, 07:56 AM
Mickey#1 Mickey#1 is offline
Re: Blower woes. Help needed.
$450! It's a 5 minute job to change that pulley. The bolt that holds it on is probably a left hand thread. The hard part of this job will be putting the belt back on. I've never changed a belt on a 2000+ so I'll let someone else comment on that.
If I were you I'd go buy a belt, pulley & a Chilton's manual. Should be less than $100. This job shouldn't take more than an hour.
Old 06-04-2010, 11:16 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
A new belt should be less than 30-bucks and the pulley less than 20-bucks. If you don't have the funds for that amount and you don't need the boost, you can continue to drive it as is, it won't hurt anything!
Old 06-09-2010, 03:11 PM
xdhd350 xdhd350 is offline
Send a message via AIM to xdhd350 Send a message via Yahoo to xdhd350 Send a message via Skype™ to xdhd350
That's correct as far as my 2001 is concerned. Left hand threads on the idler pulley bolt. I suspect it's the same on the newer model year.
$450 is a complete rip-off for a job that small. You may also want to look at salvage yards in your area for the pulley and bolt, however, I would buy a new belt at the auto parts store. Gates is a good brand to look for.
GregB
