Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-25-2010, 05:33 PM
mattd424 mattd424 is offline
gauge problem
1994 ram with 5.2 153k
ok i replaced a bulb in my gauge cluster didnt even unplug it or take all the way out now all gauges but oil pressure dont work turnsignal lights cum on headlight high beam light works and when i turn key on abs light only light that comes on speedo n rpm dead also i would greatly appreciate any help
Old 05-29-2010, 05:41 AM
copternadley copternadley is offline
Re: gauge problem
check electrical wires maybe some of them are unplugged. for gauges, I suggest you get AutoMeter, it's cheap, accurate and durable.
Old 06-03-2010, 12:00 AM
bratt bratt is offline
Re: gauge problem
check all fuses
Old 06-03-2010, 02:55 PM
Re: gauge problem
thanks for the replies i have been thru all fuses there is only 2 plug on the back and they clean and tight gas gauge and oil pressure still all i got.is it nessasary for all bulbs to be in for guages to work
Old 06-03-2010, 03:15 PM
Re: gauge problem
does the dome light work?
does any lights work on the power windows or dash?
is it just the speedo only
maybe you blew out the speedo? does the gauges still move?
Old 06-03-2010, 05:07 PM
jpb53 jpb53 is offline
Re: gauge problem
Check your grounds. Here's a wiring diagram.
Old 06-05-2010, 04:51 PM
Re: gauge problem
no gauges work the whole thing lights up tho im just missing 2 dummy lights.fuel and oilpressure the only 2 that work like normal.ty for the diagram ima go beak out my meter right now and see whats goin on cant figure out for the life of me how all this could happen just replacing 1 bulb i pulled the cluster out unplugged it put bulb in pluged up and it hasnt worked since
Old 06-11-2010, 01:25 AM
Re: gauge problem
ok im very happy now the power line in the board burnt in 1 spot i shaved down each sides of the burt hole to expose the copper and solder filled the gap everything works perfect now ty for diagram it made it alot easier
