Old 05-25-2010, 04:31 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
manually controlling the fans
hello all. im hoping someone here will be able to help me. i have an aftermarket (canned tune) PCM. this pcm is set to work with a 180 degree thermostat, however i choose to keep my stock 195 in. needless to say, my cooling fans a pretty much always on. i could send it the pcm back for a change and be without a car for who knows how long. i could just get a new/different pcm with settings to my liking, however i dont have $100 for this project. it would be much cheaper for me to buy some wire, and a couple toggle switchs, and maybe another part or 2
im basically wondering which wires i should splice into for the toggle switch(s). should i just splice right into the wiring harness at the fan shroud, or is there a certain wire on a relay i could splice into without setting an SES??
any input will help, thanks!
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 05-25-2010, 08:21 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: manually controlling the fans
Something like this?
http://www.zzperformance.com/grand_p...=194&catid=107
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-25-2010, 11:02 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Wow, they take you to the cleaners on that thing.
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 05-26-2010, 06:50 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Is there a reason you kept the 195 stat? Seems the easiest and most logical would be to put a 180 in it. If it gets cold where you live in the winter, then change it back in Nov. It takes about 2 minutes to change a t-stat in a 3800. Just my
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-26-2010, 09:40 AM
00GTP4ME's Avatar
Yeah, I've kept my 180* in for a long time and it does suck in the winter. I'm definitely going to swap the 195* back in for this winter so my car doesn't take two hours to warm up.
Old 05-27-2010, 08:45 AM
BNaylor's Avatar
BNaylor BNaylor is offline
The best method of control and safety on electrical components is via the cooling fan relays. There are a total of 3 but you should use a GM wiring diagram to properly connect the wiring.
Anyone have the instruction sheet on the ZZP kit? I wonder if the kit taps into the relays at the main fuse box.
Note: Although it may look like the cooling fans run all the time they probably don't once you get going with proper airflow to the radiator/engine and the fans are inhibited for turn on at speeds around 40 mph and up.
Timeslip 08/12/06
AF Community Guidelines
