Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-25-2010, 12:57 PM
trox trox is offline
2000 Passport lighter/ACC socket no power
Neither the cigaret lighter or the accessory socket in the back work. Fuse is good, no power to the sockets. Is there a power supply or module somewhere that can cause this? I don't have a wire schematic to look at. Is there a website I can link to that shows the wiring for the passport?
Old 05-25-2010, 01:59 PM
Cat Fuzz Cat Fuzz is offline
Re: 2000 Passport lighter/ACC socket no power
Does your cargo area socket have power? If not, I would suspect a problem with the relay. Not sure where it is but it's probably in the engine bay fuse/relay box.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 05-25-2010, 02:20 PM
Thanks for the feedback. Yes, the cargo socket is out as well. Could I be so lucky as to have a similar relay to swap it with? I guess I need to know which one is the relay for the lighter sockets first.
Old 05-25-2010, 03:13 PM
In most cases, relays are all the same in a car or there are others that are the same. I figured out that the relay you are looking for in in the dash fuse panel. You should be able to feel or hear it click when you turn the key on. You should also be able to switch it with another relay for testing.
