Old 05-24-2010, 03:20 PM
pp270 pp270 is offline
rear hub assembly change out
I have to change out a rear hub/bearing assembly. Will I need a hub puller to remove the old assembly? I know you need one for the front ones as I have done them before, but didn't know if you also needed the puller for the rear ones.
Old 06-01-2010, 11:24 PM
Larson17's Avatar
Larson17 Larson17 is offline
Re: rear hub assembly change out
I actually replaced my front right hub assembly with no hub puller. I just disconnected the strut from the hub and the other bolts holding it in place and was able to yank it right off. I don't see why you would need one for the rear, if they're the same as the front....
Just my thoughts :-)
