Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-24-2010, 12:56 PM
bill604 bill604 is offline
Tranny and differential share fluid?
Does the transmission and the differential share fluid on a 2000 V6 automatic Camry?
I got my transmission fluid changed over the weekend and when I asked about changing the differential fluid, the mechanic said that they share the same fluid and I only have to change 1 of them.
Old 05-24-2010, 01:19 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Tranny and differential share fluid?
I believe it does. It's the 4 cylinder models where they are separate. If you want you can double check the generation 4 factory service manual stickied at the top of this forum's home page.
Mike
Old 05-24-2010, 05:40 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
One way you can tell is if there is no fill or drain plug in the differential, then the answer is obvious.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
