Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 05-24-2010, 01:07 PM
84hurst 84hurst is offline
1994 3.3 leaking fuel out of exhaust
So I have a 1994 Intrepid I am working on. Has a definate misfire. I replaced the #5 injector about a month ago because the plug was soaked with fuel so I suspected a stuck injector. All was fine for a short time but now the problem is back. It is pouring fuel out of the exhaust. I pulled codes and came back with 12 27 51 43 and 21. I assume all are related to this problem. I'm guessing its a wiring or pcm issue. And ideas? Thanks guys!
Old 03-24-2012, 03:29 PM
e40water12 e40water12 is offline
Re: 1994 3.3 leaking fuel out of exhaust
I would inspect your fuel pressure regulator. The Rubber diaphram could be worn out
Old 03-24-2012, 05:20 PM
jamesslcx jamesslcx is offline
84, the pcm may be overcompensating for a lean mixture, Have you checked for vacuum leaks and all the basic sensor checks. As always start with the simple stuff first.
Old 03-24-2012, 05:26 PM
You probably know this anyway but here goes codes 21 and 51 are due to the o2 sensors, 12 is battery power disconnected, 27 is injector driver not responding and 43 is ignition coil not responding to control command. Seems like a lot but it deserves checking out.
Old 03-25-2012, 12:45 PM
Thanks for the reply guys, but the car was dismantled and its prolly a Kia by now. Never did solve the issue though...
