Old 05-23-2010, 12:41 PM
captainron478 captainron478 is offline
bent intake push rods 1988 straight 6
bought a 1988 f-150 6 cly 300 was going to junk yard has not been ran in 3-4 years.changed fuel,filter,high volume pump and computer to get injector pulse ran for 30-40-minutes ran fine shut truck off next day would start but ran rough missing on 2nd cyl found push rod bent changed lifter and push rod ran good all 6 samething shut off next day rough really bad took side cover off found 2 bent rods and some off lifters all were on intake valves and ideal what could cause this or what is going on
Old 05-23-2010, 01:00 PM
mcmalloy mcmalloy is offline
Re: bent intake push rods 1988 straight 6
your injectors are probly leaking fuel into the cylenders as it sits ,
Old 05-23-2010, 02:42 PM
what are my options for this besides new injectors due to expense of new ones
Old 05-23-2010, 09:02 PM
RahX RahX is offline
I would look at the injectors and make suree there is nothing getting into the cylinders. You might be looking at a sticky valves also.
Old 05-25-2010, 11:22 AM
FNA FNA is offline
Why would leaking fuel injectors cause bent push rods?
Old 05-25-2010, 08:37 PM
If the cylinder has a lot of fuel in it, the piston could hydrolock and keep the valve from opening. The weak link would most likely be the pushrod and it would bend.
Old 05-26-2010, 12:10 AM
mechhound mechhound is offline
This doesn't totally fit in with your description of what happened, but I would suspect a sheared nylon composite cam timing gear. The 6 cylinder doesn't have a timing chain, just 2 gears that mesh together.
Old 05-26-2010, 08:35 AM
FNA FNA is offline
"If the cylinder has a lot of fuel in it, the piston could hydrolock and keep the valve from opening"
thanx for the response - but this engine started and ran per poster, so piston can't be locked. In such a case engine won't turn over, right? If any one piston isn't moving, none of the rest are either.
I tended to think cam timing myself - possible can run albeit poorly a tooth or two off.
