Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 05-22-2010, 04:54 PM
jima4624pY2 jima4624pY2 is offline
Cruiser won't run
I have a 94 Cutlass Cruiser with a 3.1 and it will not run if i spray some starting fluid it starts,so i am thinking fuel problem checked fuel preasure 0 so i put 12v to the fuel pump wire and it showed 55 lbs then tried to start and nothing any help would be great thanks
Old 05-23-2010, 08:22 AM
maxwedge maxwedge is offline
A990 racer
Re: Cruiser won't run
Checked the fuses?
Old 05-23-2010, 04:04 PM
Originally Posted by maxwedge View Post
Checked the fuses?
did that problem is with out useing the fuel pump test lead i can't charge the fuel rails and even when they are charge it still won't run
Old 05-24-2010, 11:47 AM
A990 racer
Very tough to understand what you are saying here. If the fuel pressure is 55 when getting 12v directly to the pump, it still will not start?. Do you have injector pulse?
Old 05-24-2010, 06:08 PM
thats what i don't know i must not bcause it won't start with the rail charged were does it get injector pulse from thanks
Old 05-24-2010, 06:43 PM
A990 racer
From the crank sensor telling the pcm the engine is cranking, again how about fuses?
Old 05-25-2010, 04:52 PM
i checked all the fuses i know of the one in front by the relays the ones in the car and under the hood distrabution box if you know of any other ones i am all ears thanks
