Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-22-2010, 11:30 AM
Tourmgt Tourmgt is offline
2003 Fan Shroud Replacement
Any instructions on R & R?
Old 05-22-2010, 12:31 PM
inafogg inafogg is offline
Re: 2003 Fan Shroud Replacement
<DIV id=site-repair-guide><DIV id=window><DIV id=cont>
Welcome back, inafog96!
Manage My Vehicles View Repair Guide Current Vehicle:
2003 Chevrolet Monte Carlo 3.8L SFI OHV 6cyl 1992 Ford Truck F150 1/2 ton P/U 2WD 4.9L FI 6cyl 1997 Ford Truck Explorer 2WD 4.0L EFI 6cyl 2001 Ford Taurus 3.0L EFI DOHC 6cyl 1991 Jeep Cherokee 2WD 4.0L MFI 6cyl 1992 Buick Park Avenue 3.8L SFI OHV 6cyl 1979 Oldsmobile Cutlass 4.3L 2BL OHV 8cyl 1991 Jeep Cherokee 2WD 2.5L FI 4cyl 2004 Lincoln Truck Aviator 2WD 4.6L SFI DOHC 8cyl 1996 Pontiac Grand Prix 3.1L SFI OHV 6cyl 1989 Chrysler New Yorker 3.0L FI 6cyl 1994 Ford Truck Ranger 2WD 4.0L MFI 6cyl 1996 Pontiac Grand Am 2.4L SFI DOHC 4cyl 1997 Buick Lesabre 3.8L SFI OHV 6cyl 1995 Chrysler New Yorker 3.5L MFI 6cyl ---------Add a vehicle---------
Select a New Store
3600 N MARKET ST, WILMINGTON, DE 19802
(302) 764-5282
0 item
<DIV id=bd><DIV id=bdcontainer>
<DIV id=rightcontent>
Century, Grand Prix, Impala, Intrigue, Lumina, Monte Carlo, Regal 2001-2005
Removal & Installation
CAUTION
Use care when working underhood around the cooling fans. The fans are controlled by the Powertrain Control Module (PCM) to come on at a certain temperature, even with the engine turned off. Always disconnect the negative battery cable to prevent the fans from starting without warning.
  1. Disconnect the negative battery cable.
  2. Drain the coolant from the radiator.
    CAUTION
    Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  3. Remove the engine mount strut. Some technicians will disconnect just one and swing the strut out of the way. In this case, loosen the through bolts to prevent shearing the rubber bushings when the strut is moved out of the way for radiator removal. In some cases, it is best to remove the strut and its mounting bracket completely.
  4. Separate the cooling fan harness connector from the engine harness.
  5. Separate the low coolant level module harness connector at the module.
  6. Disconnect the radiator hoses.
  7. Remove the cooling fan assembly from the vehicle.
  8. Disconnect the automatic transaxle cooling lines from the radiator
  9. There should be two small retaining brackets at both ends of the radiator that are removed.
  10. Carefully lift the radiator up and out of the vehicle. Note that the bottom should have locating pins on each end which should fit into grommet-like rubber mounts at installation.
    Fig. Radiator and related components-Intrigue shown, others similar
    Fig. Unfasten the engine strut brace bolts . . .
    Fig. . . . then swing the strut and brace out of the way
    Fig. Remove the upper panel mounting bolts and other retainers
    Fig. Unfasten the fan electrical connector
    Fig. Remove the electric cooling fan assemblies
    Fig. Disconnect the upper, then the lower radiator hoses
    Fig. Detach the transaxle cooler lines from the radiator
    Fig. Unfasten the radiator mounting bolts
    Fig. If necessary, remove the radiator shroud . . .
    Fig. . . . then remove the radiator from the vehicle
To install:
  1. Use care when handling the radiator. It is constructed of aluminum and should be handled carefully. Install the radiator, making sure that the lower locating pins on each end fit into the grommet-like rubber mounts.
  2. Connect the transaxle cooling lines to the radiator.
  3. Assemble both the cooling fan harness connector and the low coolant level module harness connectors.
  4. Install the remaining components in the reverse order of the removal process. When refilling the cooling system, use the proper mix of DEX-COOLŽand water. Check for leaks.
CAUTION
    CAUTION
To install:
Back to Top
<DIV class=sidebar> Sorry, there are no parts available for the selected vehicle: 2003 Chevrolet Monte Carlo 3.8L SFI OHV 6cyl.
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
