Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-22-2010, 01:10 AM
Sonic Eclipse's Avatar
Sonic Eclipse Sonic Eclipse is offline
Send a message via MSN to Sonic Eclipse Send a message via Yahoo to Sonic Eclipse
Exclamation Will a 420a ECU from a '96 work in '95 Shell?
I'm looking into buying '95 Eagle Talon shell, but the motor I plan on swapping into it is from a '96.
I'm aware the '95 420a DSMs have a different ECU's than the ones from '96 down. But what I need to know is can I use the ECU from the '96 in the '95 shell? Would I have to swap out the harness as well? Is the harness a direct swap?
I just don't want to use the ECU from the '95 because they're known for having problems, at least the ones I've encountered have been junk.
- 1995 Eagle Talon TSi AWD
- 1996 Eagle Talon ESi - 5spd (RIP) -_-
- 1994 Eagle Talon ES - 5spd (sold)
- 1997 Eagle Talon TSi AWD (sold)
- 1990 Nissan 300zx TT (RIP)
Old 05-22-2010, 09:01 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Will a 420a ECU from a '96 work in '95 Shell?
The harness is different as well. 95s are a single piece and the 96+ are 2 piece connectors. Best way would be to just replace the whole harness. The coilpack connector will be different, going from the round to the flat pin. Bu I believe that's the only other difference.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-22-2010, 09:49 AM
You mean replace the 95 harness with the 96 harness? How easy is that to do?
Old 05-22-2010, 01:13 PM
david-b's Avatar
Dave is THAT guy
Shouldn't be too hard. I never had any problems with the 95 ECU personally, and never really heard of anyone else having problems with them. They're cheap enough to replace anyways. I would just keep that in there.
75 Monte Carlo
