Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-20-2010, 11:11 PM
Mickey#1 Mickey#1 is offline
Wheel hub removal
I'm helping a friend install a new wheel hub on a 2004 Explorer XLT with 4 wheel drive & abs. We removed the three bolts that hold the hub on & the axle nut. The splines on the axle are moving freely but we can't get the hub to come off. Do the hubs have to be pressed out?
Old 05-30-2010, 10:29 PM
TeamExploder TeamExploder is offline
Send a message via AIM to TeamExploder
Re: Wheel hub removal
I know this is late but it may help others in the future. The hub is probably seized on, the best thing to do is soak it in PB Blaster or JB80 for 5 minutes and the tap around it with a hammer and should free it.
1996 Explorer XLT 4X4 Auto. 4.0 OHV BWM to Fulltime and auto 4X4
1999 Malibu. 2.4L DOHC Auto
2000 Explorer XLT 4X4 Auto 4.0 SOHC
Old 06-18-2010, 09:03 AM
bigryry bigryry is offline
I tried the jb think and hammer no luck, brought it to a shop, i even rented the puller from autozone and broke it...Hydrolic puller is what i was told..Even the shop said they are a PITA
Old 06-18-2010, 09:29 AM
All the times I've done them, beating with a hammer did the trick. When you put the new one be sure to take a grinder lightly to expose clean metal and put anti-seize around it so you don't have that problem again.
