Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-20-2010, 09:56 PM
rwilber rwilber is offline
Brakes Grabbing?
Changed the master cylinder, calipers, bled the lines and now the brakes are grabbing??? Maybe about once every turn. Don't know if its in the front or back. Grabbing started after the work was done. any ideas pls???
Old 05-22-2010, 08:07 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Brakes Grabbing?
Do you mean the brakes are stopping better than it was?
What year?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-01-2010, 01:37 PM
mrwrench mrwrench is offline
sounds like the caliper pistons might be binding and sticking! might need a rebuild kit
Old 06-03-2010, 12:39 AM
bratt bratt is offline
you can get new brake calliper at auto-parts stores, rebuild ones are cheap. just ask around. I went in and got some rebuilt ones very cheap and it worked great. I saw some chips on the corners of the piston on the calliper so I just bought a rebuilt one at the local auto parts store.
