Old 05-20-2010, 05:20 PM
schri00 schri00 is offline
Question Pointing the front wheels straight ahead
Does someone know why you have to point the front wheels straight ahead when disarming the air bag system?
Thanks.
Old 05-20-2010, 08:19 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Pointing the front wheels straight ahead
It's probably because they figure you're removing the steering wheel and they want you to have the wheels straight ahead so the steering wheel will light up properly when you got to reinstall it. It might also be so the clockspring/sliding contacts are at their "neutral" position. It could also be some specific reason for the vehicle you are referring to, which is information you didn't share with us.
-Rod
Old 05-21-2010, 11:46 AM
The instructions are for a ‘97 2500 Chevy pickup. But I’ve seen the same instructions for air bag systems on other makes and models. The clockspring/sliding contacts being in their neutral position, as you said, might have to do with it, plus the impact sensors one may start getting close to past the steering wheel removal. (My guess). Thanks a lot Rod.
Old 12-25-2010, 08:02 AM
rahbudi rahbudi is offline
@schri00, this related with flexible cable for your horn and airbag with maximum rotate, so just follow the instruction
Tags
air , bag , disarming , system
