Old 05-20-2010, 12:12 AM
kahjdh's Avatar
kahjdh kahjdh is offline
Idler arm opinions
I was wondering if anybody has replaced the idler arm on their truck yet. Im a shade over 100k miles and doing some work including all tie rods and front wheel bearings and noticed that the idler is a two piece on these trucks. What im wondering is how often does the bracket part wear out vs the arm? I bought the arm but the bracket is an additional $75. Also the rear backing plates rotted on mine so I bought some replacement dorman parts but since I have to take the parking brakes apart anyway I want to know what all is needed to make them operable again? I know I need the hold down clips but do I also need shoes? Any help or experience would be greatly appreciated.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 05-20-2010, 10:03 AM
j cAT j cAT is offline
Re: Idler arm opinions
I replaced the inner tie rod on my 2000 silverado..the rubber boot has a poor seal design I modified it and it now holds the grease and keeps out the water...so 10yrs now and greasing 2X a yr. , with a lithium based grease I have no front end issues.
to replace the inner tie rods you will need a 1-3/8 open end wrench and a pipe wrench..put the pipe wrench on the relay rod do not rotate then with the open end wrench unscrew the tie rod..you will have to use a torch to heat the tie rod /relay rod end to remove ...
on installing you must use medium grade loctite on the tie rod threads. torque to about 70 ft LBS.
the rear brake shields rust out because they were never preped properly when manufactured. I cut my shields in half then installed no big deal....
If you do not cut then the axles need removal....
If your park brake shoes are worn replace them using the new hold down clips that are stronger than the ones when vehicle was manufactured..these clips must lock down those shoes securely ..if not the shoes will flop around and soon be worn out...the park brake is self adjusting at the cable end...you must adjust the shoes so they contact the inner drum when the cable ear is pulled off the shield about 1/4 of the full movement ..you must install and remove the rotor many times to do this and lock the rotor down with a few lug nuts each adjusting ..
