Old 05-19-2010, 04:23 AM
doctorhrdware doctorhrdware is offline
Smile Control Arm
My 97 GP SE has around 156,000. Originally I was going to replace the parts on the control arm. The ball joint and the 2 control arm bushings. The approximate cost was $66.50 with tax. But that does not include the cost to have the bushings installed. When the drive shaft on my Wife's Chevy truck needed u-joints installed. I was charged $20 for the front u-joint and $20 for the rear, so that would be an extra $40 added on to the price for the control arm repair price. So the total cost for the parts and with installation charge would be $106.50, plus the time wasted taking the control arms to a place to take out the old bushing and install the new bushings. The other problem with the place that is installing the bushings could damage the bushings. Which are the only parts that I can't install with out doing any damage to them.
With searching the internet, I have found Dorman control arm for around $99.60, including tax includes, and the ball joint and bushings. So I am really leaning towards the Dorman control arms. I think that would be the best bet and the fastest way to get the work done. I am going to also replace both sides. I am going to replace the driver's side first. That is the worst side, it is constantlyis making loud popping noises, and metal on metal scrapping noise. But I will be doing one side at a time. It will much easier on my back and less pain. I am hoping that I have a much easier time, then I did with the rear brakes and the rear suspension.
Old 05-19-2010, 08:13 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: Control Arm
I did the same for my driver side CA. Just replaced the entire part, bushings included.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 05-19-2010, 09:53 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Control Arm
I agree with JonJon68, go with the Dorman part, they are nice quality and much easier to just replace the whole thing then to deal with repairing your OEM control arm.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-19-2010, 07:59 PM
Re: Control Arm
So that is what I will do. Since it will be much easier to just replace the complete control arm. They are in stock so I am going to replace both sides.
Old 05-19-2010, 09:00 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Control Arm
Don't forget an alignment when you are done! After I replaced mine, my car was so out of alignment that the steering wheel would not align itself back to center after I accellerated through a turn.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-19-2010, 09:12 PM
Re: Control Arm
I was going to get that done after I get new tires on the rear and get the 4 wheel alignment.
Old 05-27-2010, 09:53 AM
thecrow1986 thecrow1986 is offline
Re: Control Arm
i put those dorman arms in my car and they work great.
Old 05-27-2010, 02:48 PM
Re: Control Arm
Thanks for the heads up on the Dorman control arms. I used Dorman caliper brackets on the wife's explorer. The quality of the Dorman was so much better then A1Cardone. I will never use A1Cardone again.
