Old 05-17-2010, 05:35 PM
KrsDrft KrsDrft is offline
Street Drift spec s15
Hey I'm new around here and decided to get back into model building after 10 years or so.
So here is my build of a japan street style s15 using a fujima 1/24. let me know what you guys think and any help will be appreciated.
fujima s15 w/impul rims,i think
origin lab style bodykit,still need to sand
plan to make them into deep dish wheels,just testing at moment
sloppy interior,scratch built cage and gauges
heres undercarriage and suspension ,wanted to go with a street look where you buy suspension parts for the product not the color,also wanted it to look like various tein products
Old 05-17-2010, 07:39 PM
da_ashman's Avatar
Re: Street Drift spec s15
Welcome back, great work on the undercarriage!!
Old 05-17-2010, 07:40 PM
da_ashman's Avatar
Old 05-17-2010, 08:36 PM
thanks alot da ashman
Heres a update from tonight,scratchbuilt overfenders, also used masking tape to make a low offset rear rim to see how big i need them
Old 05-18-2010, 02:40 AM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
This is looking sweet! The wide rear fenders look sweet and I like the rear windscreen spoiler!
A question: What putty did you use?
or
Old 05-18-2010, 06:26 AM
testors contour putty i believe. Why?
Old 05-19-2010, 12:30 AM
Drift F.C's Avatar
I've got a Mercury with some pretty big low spots in the roof because of a chop and if I sand to much, I will go through the plastic, like what has actually happened!
or
Old 05-20-2010, 09:14 PM
slight update, built more crap for the undercarriage,again car didnt come with an engine so i have to improve other parts to compensate,new sway bar,and under body brace,made deep dish rims so i have the problem of the tires not fitting properly,any idea's anyone? car is very close to being complete,so expect some good updates soon.
Old 05-22-2010, 01:17 PM
rollin80s rollin80s is offline
that is some deep offset. as for tires, you might need to get another set of tires and cut and splice them to make them wider.
Old 05-22-2010, 05:09 PM
thnx for the suggestion, i still haven't decided how deep i want to go. So i made various pairs of rim lips,some fit within the stock body and others require the fender flares i made. In the end i may do it so that everything is interchangeable and not permanent with glue.
Old 05-25-2010, 08:38 PM
okay so now i remeber why i quit, because i suck and lose patienance at the clear parts stage!!!!
here it is,about as done as im going to get it, im just gonna leave it before i get too aggravated and come back and fix things later
and i had to use an old interior pic because with the front bumper glued in place i cant get the body off with breaking it lose,also hard to photografh it now with the clear glass all around.
Old 05-29-2010, 07:14 AM
was finally sunny so i took advantage of it and took some outdoor pics,still need to make license plates and maybe some of the decals
