Old 05-17-2010, 11:55 AM
gene5118 gene5118 is offline
401 fault
2002 F150 4.2 V6 the service engine light keeps coming on. I have replaced the ptfe sensor, checked the egr pipes for blockage. I took the egr valve off, it had carbon in it but the valve moved up and down, cleaned it as best as I could. Put everything back together and no light yet, but this is the second ptfe sensor I have repalced in 6 months. Anyone else ever have this?
Old 05-17-2010, 02:37 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 401 fault
When you had the EGR off, did you clean the passages in the intake? If there is a blockage in the passages, that code will occur.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-18-2010, 08:02 AM
Re: 401 fault
No I did not, didn't want anything going into the intake. How can you do it without getting carbon in the intake?
Old 05-18-2010, 06:55 PM
way2old's Avatar
TOKEN HILLBILLY
Re: 401 fault
There will be some fall inside. Use a small vacuum with a small nozzle and vacuum it out as you clean. A little falling inside the intake will not hurt anything.
Old 06-08-2010, 08:56 PM
Re: 401 fault
Light has not come on since PDFE sensor was changed
