Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 05-17-2010, 12:22 PM
jnj1181 jnj1181 is offline
3.4l Head Crack
1999 3.4l v-6. 1 head has a barely visible crack between the valves on 1 cylinder. Is this something that should be replaced?
Old 05-17-2010, 12:59 PM
maxwedge maxwedge is offline
A990 racer
Re: 3.4l Head Crack
Welcome to AF. What is the alternative? You cannot reuse a cracked head!
Old 05-17-2010, 01:48 PM
MrPbody MrPbody is offline
AF -Advisor
Re: 3.4l Head Crack
Iron head or aluminum? Iron heads ARE very difficult to repair, making it much less expensive to replace it. The same heads were used on 2.8 and 3.1, as well as 3.4. The aluminum head, however, can be repaired relatively easily.
If this is a "twin cam" 3.4, you probably would have a rough time finding another. If it's the canted-valve OHV version, repair it or replace it.
If you simply can't FIND another OR someone to help repair it, PM me and we'll hook you up.
Jim
Old 05-17-2010, 03:19 PM
Re: 3.4l Head Crack
Thanks guys, thats what I thought, just wanted to make sure.
Old 06-16-2010, 12:09 PM
uspres2020 uspres2020 is offline
Re: 3.4l Head Crack
Is it possible to repair a crack on an aluminum head as I think I am dealing with one right now with air constantly reappearing in my coolant causing the car to heat up and overflow the expansion tank.
Does anyone have a stop leak that they recommend that could work for such a situation. I have already replaced all the gaskets with the help of a mechanic friend and we did not see any cracks or signs of warpage but some are so minscule that they can not be seen and I am not sure what else could be causing my issue.
Old 06-16-2010, 12:32 PM
A990 racer
Re: 3.4l Head Crack
Nice to know what car/engine here. Also if the head were cracked and combustion gas was entering the cooling system, the rad hoses would get pressurized shortly after running the engine from a cold start.
Old 06-16-2010, 01:42 PM
Re: 3.4l Head Crack
Its a 99 grand am. There is a whole thread under the grand am section called overheating about it.
Do you mean the rad hoses to the expansion tank because I don't believe that they have been getting stiff right away like that.
In a couple of hours I am going to try to do a pressure test on the system to see if it is holding pressure.
