Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-16-2010, 08:15 PM
bhs0432 bhs0432 is offline
2000 century Dirver side a/c blowing hotter than passenger side
I have a 2000 century with 77k miles. Recently the drive side a/c is hotter than the passenger side. Tried adding coolant but driver side is still hotter. Any ideas?
Old 05-17-2010, 08:48 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 2000 century Dirver side a/c blowing hotter than passenger side
welcome to AF.
By recently added coolant, do you mean R134 refrigerant or engine coolant?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-17-2010, 05:31 PM
Sorry meant to say refrigerant, but yes it was R134 refrigerant
Old 05-18-2010, 08:58 AM
richtazz's Avatar
next question, does your car have the dual zone (separate temp controls for driver and passenger sides) or single zone HVAC system?
Old 05-18-2010, 05:00 PM
it does have dual zone
Old 05-20-2010, 11:32 AM
richtazz's Avatar
Your problem is most likely the drivers side temp actuator is not switching all the way to cold, this is a pretty common issue. The other possibility is low refrigerant or mildew blocking airflow through the evap core. The way the HVAC system is designed, the passenger side gets it's cooled air from the inlet side of the evap core, and the drivers side is on the outlet side. When refrigerant levels are low, the pass side will still blow cool, but the drivers side won't. Because of this design, the drivers side section of the evap core is also the most likely to get plugged up with mildew.
Old 02-04-2013, 10:50 PM
Archie06930's Avatar
Archie06930 Archie06930 is offline
I just went through the hassle of replacing the driver's side blender door actuator because of this problem, but apparently the actuator wasn't the problem. I will try getting the freon charged and see if that fixes it. Thanks for this tip, I didn't know what to try next since I was sure it had to be the actuator but it turned out not to be....
Old 02-05-2013, 04:59 PM
Tech II Tech II is offline
If low on freon, the freon can "short circuit" through one half the evaporator, causing one side to be hot, and the other cool......
However, the system should be recovered to see how much of a loss you have(by weight), and have the leak repaired first....
The Following User Says Thank You to Tech II For This Useful Post:
Archie06930 (02-05-2013)
Old 02-05-2013, 09:00 PM
This is a 2004 model that has never been recharged so being low on freon is a definite possibilty.
I have always wondered if freon loses it's refrigerant properties or if it actually leaks out of a system. Anyone know for sure?
Old 02-06-2013, 03:45 PM
It leaks out.....
Archie06930 (02-06-2013)
