Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-03-2003, 04:11 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Front lower tiebar...
Recently I swapped out my 13mm 6th gen Civic Si rear swaybar I had on my '00 Civic DX coupe, for an almost twice as large 22mm Integra Type-R rear swaybar. A couple days after having it installed, one of the endlinks which is bolted to a special collar to fit the larger endlink mounts to the bar, popped out while driving. Needless to say $50 later I had to order a new endlink (which I should have done in the first place) because of something I had to do with that link while I had it in my Si swaybar which it worked for that bar, but doesn't for this much larger one.
Anywho, the time I had the ITR swaybar on, I didin't really push the car to any limits to see how any snap oversteer would be with it installed in place. I did notice some better handling performance, but nothing unexpected. In the meantime I've disconnected the other connected endlink as to not cause any off balance of the car to any one side, so the bar is bolted to the subframe, but not the actual suspension itself at the LCAs, so essentially I'm driving with no rear swaybar right now. I've driven my fav local mountain passes recently since I disconnected the ITR bar, and I have a good gut feeling I won't be able to drive those roads how I did last weekend once I get the bar all re-attached because I'll have some serious understeer problems. Right now the car feels surprisingly balanced, although I have no front swaybar either, which brings me to my question.
Until I can figure out a solution to getting a front swaybar weather it be aftermarket (Neuspeed I was looking at) or OEM if I can find the appropriate control arms for the front that'll accept an OEM swaybar, would in the meantime putting a FRONT lower tiebar be beneficial any? Would that dial in even slightly more understeer to better balance the set up, or would it be a complete waste of money? They aren't very expensive, so I'm figuring I may just spring for one.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 05-04-2003, 11:15 PM
BullShifter's Avatar
If you only have one sway-bar on the car it should be on the rear. FWD benefit from rear sway-bar . . .RWD front sway-bar . . .
Old 05-05-2003, 12:26 AM
Cali Guy
I HAVE a swaybar on, but it's a pretty large Integra Type-R rearsway bar, which compared to a puny Si swaybar (rear) can have some pretty negative effects on the car if you try to any real extreme handling with it, like I go when I auto-x. That's why you need a small front swaybar to help balance things out, otherwise you'll oversteer as much as an old 70's muscle car.
hessemer69 on AIM
front lower strut bar got v-tec? '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 01-19-2004 09:44 PM
front lower valence? knorwj Exterior | bodykits | Lighting 4 01-09-2004 12:37 PM
Neuspeed's Front Lower X-Brace EFStali '88 - '91 Civic | CRX | Wagon | Shuttlee 6 08-07-2003 10:53 AM
Front Lower Tie Bar BullShifter '88 - '91 Civic | CRX | Wagon | Shuttlee 7 04-10-2003 12:46 AM
FS: 5" Front lowering kit and Belltech Rear Swaybar... G-ZIGN General Discussion 0 06-15-2002 02:22 PM
