Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-16-2010, 12:15 PM
dirtycurty dirtycurty is offline
92 laser no spark help
Cant get spark changed the crankshaft camshaft angle sensor,coil,ignition power transister, checked the timing marks there good and the harness checkes out good to any one have any ideas. THIS IS A 92 LASER NON TURBO WITH THE 2.0
Old 05-16-2010, 01:49 PM
jdl jdl is offline
Re: 92 laser no spark help
Did you check primary voltage at the coil, black wire with white tracer, goes hot when you turn on the key. Did you check for any applicable trouble codes?
Old 05-16-2010, 02:12 PM
i did check it it reads fine i cant get any codes to read.
Old 05-16-2010, 05:12 PM
jdl jdl is offline
Hey, try this.
Old 05-16-2010, 07:45 PM
I tryed that and it all checks out ok i been threw the book front to back. i have tested all the wires put all new parts to do with the spark still nothing, any more ideas lol thanks for the help.
Old 05-16-2010, 07:52 PM
ned032002's Avatar
ned032002 ned032002 is offline
What did you use to check for spark?
I live about an hour from you! just noticed that.
Old 05-16-2010, 08:47 PM
i have tryed testing it with the plug volt meter and test light i have even held on to the plug nothing at all. i took the hole harness apart tonight check all the wires i have power to everything. Have any ideas.
Old 05-16-2010, 08:51 PM
ned032002's Avatar
Bad wires? Did you have this car running before?
Old 05-16-2010, 09:38 PM
Yes i was driving it down the road and it shut off like some one turned the key off its got me stumped.
