Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-03-2003, 03:56 AM
J_Spec_NiTeMaRe's Avatar
J_Spec_NiTeMaRe J_Spec_NiTeMaRe is offline
Send a message via AIM to J_Spec_NiTeMaRe
Water in CAI
Today, it rained hard as hell in SoCal. My friend has a 94 Integ LS, with an AEM CAI, and got hydrolocked. He didn't know not to crank it, and did so. Regardless of what actually caused it, the puddle or the immediate cranking, there is now a "clack clack clack" sound. I think it's a bent rod...anyone have any insight? What should we do? Thanks.
Old 05-03-2003, 02:37 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
glad i didn't go home this weekend. You can you be sure it hydrolocked? You gotta go pretty damn deep into a puddle esp. becasue of the dirt/water deflector on the bottom of where the cai should be.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 05-03-2003, 03:12 PM
the splash guard was cut away. however, we still dont know what to do. he is going to get it checked out, but what if its not just the rod thats bent? what if there is more damage? should we just swap out for a gsr? anyone?
Old 05-03-2003, 05:21 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
if it got hydrolocked, you wouldnt be able to turn it over anyways, cuz water cant compress, and the damage probably occured wqhen it locked, not when he tried to crank it, imagine driving and your engine is spinning pretty fast, then water gos into the cylinder, piston starts going up, then it gets to a point where it cdant go anywhere, and your engine just stops, the crank is pushing up and at a high speed, then when the piston stops, all that force from the crank has got to go somewhere, and it probably will go right to the rod and bend it, but it would be much cheaper to take it out and rebuild it that to get a GSR swap, but if hes been wanting to for a while, its the perfect time to. or he could just get the B18c1 longblock and ECU/harness from a GSR and do some wiring work, and then you got the GSAR power and the lower rpm's on the freeway, wont be as fast as a normal GSR cuz of taller gearing tho.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
Rain Water+Cai atticus951 Integra 3 05-31-2005 02:18 AM
