Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 05-15-2010, 06:00 PM
KoopaTrooper KoopaTrooper is offline
TOD Code 28
I'm pulling a TOD Code 28, the car drives fine in 2wd and 4W H and L. But when in 2DH the two reaer lights on the indicator flash and eventually the check light comes on on the TOD display.
According to the Workshop Manual the workflow is to check for Voltage between pins 5 and 19...but it doesn't say pins on WHAT...I'm assuming the TOD ECU, but according to the diagram in the workshop manual the 30 pin connector to the ECU don't match up, mean to say no matter how I spin it or count it there's no wire going to 19...i dunno I'm lost.
I guess, really all I want to know is am I checking the right pins on the right device. I'm looking at the computer under the seat.
Old 05-17-2010, 09:26 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: TOD Code 28
code 28 - Axle Disconnect Output & Axle Switch Output Abnormal
My FSM is ay home, so I can't be more help now.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 05-17-2010, 11:26 AM
fourwd1's Avatar
AF -Advisor
Re: TOD Code 28
OK, it drives fine, but is it really in 4WD? Is the front axle really locking?
You'd probably have to put the vehicle up on jackstands and put it in 4WD H and L to be sure.
89 4Runner - stock
