Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 05-15-2010, 09:26 AM
scarecrow0529 scarecrow0529 is offline
what engine is this.
what engine is this. 89 honda crx.
Old 05-15-2010, 09:44 AM
jdl jdl is offline
Re: what engine is this.
If that is the original engine, look at the serial number/vin, the first 5 places, indicate the engine. On the outside, look through windshield, driver side corner of dash. The engine iD starts with D.
Old 05-15-2010, 09:58 AM
sorry should of mentioned this is not the original engine.
Old 05-15-2010, 10:03 AM
jdl jdl is offline
Sorry, I can't help you. I guess you could look at cylinder head or block casting numbers, then do a web search?
Old 05-16-2010, 09:07 PM
TransWorldHonda's Avatar
TransWorldHonda TransWorldHonda is offline
Send a message via AIM to TransWorldHonda
It's a D15B. Found in the 1988 CR-X 1.5x...which is pretty rare. Also found in Japanese Civics.
  • Displacement : 1,493 cc (91.1 cu in)
  • Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.33 in)
  • Compression : 9.2:1
  • Power : 106 hp (96.9 kW, 105 ps) @ 6500 rpm
  • Torque : 115 ft·lbf (13.2 kg/m) @ 4500 rpm
  • Rev limiter : 7900 rpm
  • Valvetrain : SOHC (4 valves per cylinder)
Old 05-16-2010, 09:17 PM
Skyline8819 Skyline8819 is offline
Dude... The engine model code is clearly written on the valve cover... D15 B
Old 05-17-2010, 07:27 PM
d15b2 or b6.
