Old 05-15-2010, 04:06 AM
ronfenton ronfenton is offline
Help, 99 Ignition switch major problem
Hi
I have a problem with my 99 4x4 Blazer ignition switch that I need a bit of advice on.
When I turn the engine off it won't always go back to the off position. Pressing the button doesn't always work and I have to fiddle with it back and forth before it eventually turns off.
Also, no matter what position the switch is in I can take the key out even when driving along.
Question is how easy is it to change the barrel? Also I have a spare, wrecked blazer that I have been taking parts off and it has a good switch so I can swap it over. What parts will I need to swap?
Problem is these cars are very rare here in the UK (and I have 2!) and also manuals are very hard to find.
Thanks in advance for any help.
Cheers, Ron
Old 05-15-2010, 07:20 AM
old_master's Avatar
Advisor/Moderator
Re: Help, 99 Ignition switch major problem
Have you tried a different key? Sometimes the key can cause similar problems if there is a burr on it.
This might help. The thread is about 6 years old, but the information is still acurate.
http://www.automotiveforums.com/vbul...d.php?t=287636
You have to know how it works,
to figure out why it doesn't.
