Old 05-14-2010, 06:56 PM
glc4123 glc4123 is offline
1997 pontiac grand prix front hub sensor test
i own a 1997 pontiac grand prix, the abs & trac-lights come on and will not go off till turn off car. i been hearing a noise in front passenger side when starting out and seems to fade away after running a few miles. my question is can you test sensor on the hub with a multimeter to see if what side is bad and if so what are the readings?
Old 05-14-2010, 08:41 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1997 pontiac grand prix front hub sensor test
Yes. On ohms just go across the two pins located at the electrical connector hub side. You should see a reading of around 1K ohms resistance. Also, you can check the sensor output but it requires turning the wheel.
Timeslip 08/12/06
AF Community Guidelines
Old 05-18-2010, 01:18 PM
thanks for the help b.naylor.
