Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-03-2003, 01:08 AM
theDUDE theDUDE is offline
A quick Radiator Question
I"ve noticed a little smoke coming out of my radiator today and I also noticed that the top part of the radiator there was coolant leaking from somewhere??? CAn a radiator be fixed of do I have to replace it with a new one?
Old 05-03-2003, 03:38 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
i haven't really looked at my integra there, but a radiator has a valve (or more like a hole) at the top where if the pressure gets too high, the fluid will just leak out the top. Should be normal. The hole should be near the radiator cap.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 05-03-2003, 08:40 PM
What do you mean by pressure gets to high?? And its normal for coolant to leak around the top plastic part on the radiator?
Old 05-03-2003, 09:28 PM
PV=NRT
Volume and temperature are directly related. When the temperature goes up, so do the pressure and the volume. Since the volume is larger and there isn't enough room in the radiator, there is an overflow valve that lets the expanded liquid drip off. Then again, I haven't looked at the integras, but it should be the same for most/all cars.
Clear Corners
Iridium Spark Plugs
Old 05-07-2003, 01:06 AM
Ok now it is leaking more coolant than before. It seems like theres a leak near the radiator cap. I've try using that radiator sealant and it doesn't work. HELP PLEASE???
Old 05-07-2003, 03:52 AM
is the car overheating? Like the temperature guage? You must pinpoint the leak. If the leak is coming out from near the cap the radiator sealer ain't gonna do jack. If it is a crack in the plastic ( a small one) you may want to try that shit that is like clay but then turns hard as steel (they sell it at car part stores). If that don't work, get a new radiator or you gonna overheat your engine.
Clear Corners
Iridium Spark Plugs
Old 05-07-2003, 08:47 AM
paris paris is offline
hay the same thing happend to my 94 rs and my car began to overheat so we just replaced it the radiator range from 150-200 dollars and its a do it your self job it took us at least an hour
Old 05-08-2003, 01:10 AM
The car doesn't over heat, and the radiator fan doesn't come on?
Old 05-08-2003, 04:49 AM
check the fuse for the fan. Check the level of the radiator fluid. Is it low?
Clear Corners
Iridium Spark Plugs
Old 05-08-2003, 01:27 PM
Just checked the fuse earlier and its ok. But the radiator fan does not work still??? And the coolant in the overflow tank is empty? I just filled it up yesturday?
Old 12-09-2003, 03:07 AM
organizedevolution organizedevolution is offline
Re: A quick Radiator Question
Did you ever find the cause of this problem? I just bought a '99 LS and having the same problem. I just read an article about the Integra aluminum/plastic radiator developing leaks after being power flushed (which normally happens at a dealership during their routine service after accepting a trade-in). I'd like to find out if this is valid, and if so, whether there is any possiblity of having the dealership pay for the damages (it was a Honda dealership - they should know better )
Old 02-18-2004, 10:40 PM
ERO ERO is offline
94 LS --I just noticed my radiator blowing steam and fluid around the top of the rad settling in the rim. My temp gage does not indicate overheating, I will monitor this situation and report back.
Old 02-18-2004, 10:46 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
My god what can I say about this?
Old 02-19-2004, 12:32 AM
integralover's Avatar
integralover integralover is offline
LOL
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 02-19-2004, 01:11 PM
ERO ERO is offline
Radiator leaks may be obvious to a the couple of experts here. My guess is some of us are trying to avoid replacing the radiator.
If you have nothing to offer, I suggest finding another thread.
Newbie. Have a quick radio question fquinonez 3 Series 0 07-16-2002 02:49 PM
Quick ECU question ntrddragn Integra 7 06-12-2002 01:59 PM
Ok, quick easy question JRuner1 Car Audio 0 04-27-2002 01:50 PM
Quick stereo question Eskamoe '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 09-22-2001 01:28 PM
