Old 05-14-2010, 01:15 AM
hunter4ever12 hunter4ever12 is offline
285/75/r16 vs. 265/75/r16
Alright so the tires I choose will be going on my 1992 K1500 with a 2" lift. So i know both will fit but which ones in your opinion are the better tire to put on it. What are the pros and cons of each? This truck will be mainly a daily driver but it will see quite a bit of off road time as well during the fall and winter due to hunting season. So which is the better choice over all and why?
Thanks in advance
Wesley
Old 05-18-2010, 01:54 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 285/75/r16 vs. 265/75/r16
There's no real difference in the two as far as performance is concerned. If you're going to use all terrain, they'll be loud at highway speeds, period. On/off road tires are better tuned for the road but will sacrifice some of the lug cleaning ability that ATs have.
265 vs 285...you get about 2cm wider contact patch and a slightly taller tire. The main issue would be if the wider tire will rub against anything in the wheel wells as the suspension travels and going lock-to-lock with the steering.
I'll note that the OEM tires were 225/75/15 or 235/75/15...these are notably smaller in circumference than what you're looking at. A change this dramatic will require recalibration of the speed sensor (since you mention it will be a daily driver) to keep your speedomoeter and odometer correct.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
