Old 05-13-2010, 07:27 PM
rw1644h rw1644h is offline
Shorter Serpentine Belt possibility
My A/C compressor took a turn for the worse on my 99 Cherokee L6 4.0. Is it possible to use the Serp belt spec'd for a non-A/C vehicle? I can't affford to drop $500 bucks on a repair job right now. The Serp belt for vehicle with a/c is 95" long. The one for non-a/c is 79" long. If it is, in fact, possible to do this, is the belt routing the same (less the a/c pulley, of course) ?
Old 05-14-2010, 07:23 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Shorter Serpentine Belt possibility
Yep, it is. It's likely that you have the diagram for the different routing on the sticker under the hood.
In the future, just start one thread on the topic if you would. I've closed the others for you.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-14-2010, 08:42 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
As fred said, usually the sticker will have the routing for both and that should solve the issue.
I will say as a word of "caution" that over time the bearings on serpentine driven accessories tend to work in tandem (ie-when begins to bobble, the other 180* to it will begin to "counter-bobble"). So when you remove or replace one item in the sequence, something else is bound to fail not to far off in time.
