Old 05-13-2010, 10:19 AM
Poor boy ways Poor boy ways is offline
Red face 5 speed manual transmission 95 s-10..grinding
I just bought a 95 s-10 LS ex-cab 4.6, Z vin with 186k miles and a 5 speed manual transmission.
My only real trouble is a grinding sound when i let out the clutch in first gear as it starts to roll i get a grinding noise from the transmission and you can run through the rest of the gears , even float them . I have been told everything from lose spring in the clutch assembly, to the insert gear is bad or just replace the whole thing. I can believe its trashed it just shifts to good expect for starting out. but i not a pro . So any input?
Old 05-13-2010, 11:31 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 5 speed manual transmission 95 s-10..grinding
Does it make same noise in reverse or if you take off in second gear?
MT
Old 05-13-2010, 11:43 AM
yes it does, in reverse and 2nd as well . It may do it rarely if your down shifting in to 2nd or 3rd ...ie when turning a corning ...it seem to be some what RPM related somtimes.
Old 05-13-2010, 12:10 PM
MT-2500's Avatar
AF - Advisor
Better check your clutch plate and pressure plate and throw out bearing.
With transmission in neutral does it make noise when you hold clutch pedal down?
MT
Old 05-13-2010, 02:39 PM
It's does not make any noise when the clutch is depressed.
Old 05-13-2010, 03:25 PM
MT-2500's Avatar
AF - Advisor
Better pull transmission and have a look at the clutch.
MT
Old 05-13-2010, 03:45 PM
I hope to get to it this weekend, Thanks for the input
Old 05-13-2010, 04:36 PM
MT-2500's Avatar
AF - Advisor
Do not forget to check pilot bearing to.
You are welcome and let us know how it goes.
MT
Old 06-18-2010, 01:37 PM
After all the running around and stuff sure enough it was the clutch and I was able to get it done for $ 310 . The big name shops in town wanted 800, 900 and one even wanted 1175 to replace the clutch. Thank God for a honest Mech and thanks for you input as well.
Old 06-18-2010, 01:43 PM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went.
MT
