Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-12-2010, 11:29 PM
sgbuick sgbuick is offline
Discolored upper dash on 96
My 96 has a dash top that discolored and turned brownish, presumably from sun exposure, anyone else have this problem and/or cleaning solution? Thx.
Old 05-13-2010, 08:13 PM
j cAT j cAT is offline
Re: Discolored upper dash on 96
this is the coating fading. the vinyl is showing which is brown/tan in color..
my 1996 impala med gray interior has had this happen about 5yrs now...I obviously did not want to buy a new one since this was carefully cleaned and protected from UV damage...
I found that this material has / is dyed with a water based dye .that this can be coated with the proper technic to be sucessful ...
I payed 35.oo for the dye and removed the dash to apply [with brush] this product. I used 5 coats then buffed to a new finish look that now 5yrs later still looks new..
later I found these water based dyes are also used in the coloring of the leather seats...my seats I have touched up...then I also used this on other vehicles...
Old 05-14-2010, 04:37 AM
EngineandJuice EngineandJuice is offline
Is this a new thing or does this apply to most vehicles? If you somehow found say an 80 something caprice with a good dash could this be applied?
Old 05-14-2010, 08:33 AM
if the material is leather or vinyl it will work...
surface prep will be the most important factor in this , to be successful..
the company LEATHER TECHNOLOGIES IN ROANOAKE VA is where I purchased these dye products..
Old 05-14-2010, 01:47 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Or you could just buy a Dash Mat and cover it up..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 11-02-2010, 12:22 PM
rhomo rhomo is offline
I bought a dash mat from car covers direct.
Old 11-02-2010, 03:02 PM
Blt2Lst's Avatar
Problem solved, or at least, covered up..
1992 Camry LE 2.2
1996 Suzuki RMX250
