Need help for my 1988 Toyota pick up
Need help with my 1988 Toyota Pick up truck, Has the 22RE Engine Auto
I was driving it to friends house and it stalled out on me, i try starting it back up and it started to go and the engine really wanted to stay going but then quit again... so i try again and it turns over but engine isnt trying to fire up... let it stand for 3 mins try to start again and it starts to run for about 5sec then quits again, sounds like its not getting gas only little at a time and there is half a tank. Any help would be great, this is my only vehicle for work and dont have the money to pay someone to find it out for me, im thinking it might be a clogged fuel filter or something to do with the fuel pump ? thanks and hope to get some help. |
Re: Need help for my 1988 Toyota pick up
Does the 22RE have the air-flow "volometer" (whatever it's called) built into the air intake?
My v6 has this directly above the air filter. It has a large, flat wire connector attached. It went out once and had the kind of severe, immediate fuel-starvation symptom you describe. Pressing on the gas just a little and it would stall. The reason I mention it: it seems odd to me for a fuel filter to clog immediately unless you just filled it with gas and got some really dirty gas. Usually these clog over time and manifest their restriction under heavier loads (cruising at speed, accelerating hard). For it to be so suddenly sensitive, it seems like it would be something like I described above, or a catastrophic failure with the fuel pump? Does it die even at idle? Or, only when driving/accelerating? (PS: If you edit those 3 duplicate posts you'll see a button to delete them.). |
thanks for the reply, i just went and tried it and now there is nothing, it turns over but wont fire up, i replaced the Fuel pump Relay and it didnt help, is there anyway i can tell if the fuel pump is gone?
thanks for the help. |
PS : Right before i took the Truck out i stuck a hoose down into the gas tank to get some gas out for my atv, maybe it mixed the dirt up in it and got it clogged.
Your problem could be several things in addition to a clogged filter-
vac leaks in the air intake system bad Ckt Opening rly bad fuel press regulator To check fuel pump, shotr the Fp and +B terminals in the test connector, turn key to On position. You should be able to feel the press in the fuel line at the filter input or the cold start injector.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
Alright thanks for the help, gonna go out today and see what i can come up with.
Well just checked and looks like its the fuel pump, when i hook power to it... it doesnt work at all, could be the Connector wires but highly dought it, gonna check them anyway, Couple months ago when hooked up power i could here the fuel pump running... now i here nothing at all.
If you fed 12V directly to it, it should work.
Check the wiring to be sure, before pulling the pump.
yea thanks already did that, i found out that it was the fuel pump sending unit that is Gone on it, which is the cheapest part out of the 3 anyway.
That's good news.
except the fact i just found out there near impossible to buy now, gonna have to search very very good for the next couple of weeks, maybe a used one will show up, apparently there is a garage down the road that will repair them for the right price.
Well i just went over it and hooked it back up and nope still wont go, i spray some stuff into the Air box and it starts to go but stops, so its still not getting gas but the fuel pump works, so i have no idea what it is now.
any help would be great. |
