Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-12-2010, 08:09 PM
viper32435 viper32435 is offline
saturn heads
will the dohc head fit or bolt up on the sohc block or are they the same block just different heads if so i dont have to buy a whole engine just the computer right ?
Old 05-14-2010, 12:35 PM
Cat Fuzz Cat Fuzz is offline
Re: saturn heads
I'm pretty sure the heads are interchangeable but I thought I read somewhere that it's better just to swap in a complete DOHC long block. Just make sure you get one with the proper EGR valve mount for your year and later Saturns use one coolant temp sensor for gauge and PCM while earlier use two. 91 and 92 engines have a different crank tone wheel and are not compatible with later cars.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
