Old 05-12-2010, 12:19 PM
twitty twitty is offline
1&4 cylinder no spark
I have a 93 lumina 3.1 I changed plugs, wires and coil pak 1&4. Sometimes the car starts with all 6 firing. I drive a few blocks 1&4 quit firing. Other times i can drive a few miles before it quits firing. The car never dies though, Just runs rough due to only 4 cylnders firing. Any input would be greatly appreciated
Old 05-12-2010, 01:01 PM
maxwedge maxwedge is offline
A990 racer
Re: 1&4 cylinder no spark
Welcome to AF. More than likely this is the ign module, assuming all else checks out.
Old 05-13-2010, 08:35 PM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
1 and 4 run off the same coil on the L82 3.1L I suspect same for your year. replace the 1/4 coil after checking it for proper resistances / loose or corroded connections (the coil to ign module blade connectors).
replacement coil doesnt mean it works. use a multimeter. but ya after that go for replacing module
Old 05-16-2010, 04:19 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Since Twitty has already replaced the coil, I agree with MAXWEDGE next is the ign. module replacement unless they take it to a shop to get it checked first.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 05-17-2010, 12:07 AM
Thanks for the info. The prongs on module look good. I guess I wll pull it and see if there is anything happening on the backside. And I agree Bearwulf, Grandparents do rule. Also do you have that tboned 91 euro?
Old 05-17-2010, 02:16 AM
Bearwulf's Avatar
Yes I still have the t-boned '91. Take the IM into shop or even some parts houses for testing.
97-Lumina LS
Old 05-30-2010, 09:42 AM
OK I pulled the mod and had it tested. Yup it was bad. Installed a new 1 The car runs fine. Thanks for the help fellas.
