Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 05-11-2010, 09:37 PM
khill1125 khill1125 is offline
1989 22r ignition problems!!!
I have a 1989 22r that was resurrected after 6yrs of abandonment. Everything has been replaced in the fuel system. New plugs,wires,stator,cap and rotor has been replaced on the ignition portion. The thing will fire part of the time, don't know if its the coil, module, bad ground, etc. Any info would be a great help!!!
Old 05-12-2010, 08:20 PM
auto89 auto89 is offline
Re: 1989 22r ignition problems!!!
Can you be more specific about firing part of the time? Does it idle well for 5 minutes and stop? Misfire/stall on load regardless of the length of time the engine idles?
Old 05-12-2010, 08:45 PM
Fixed the problem today! Cleaned every ground, and every electrical connection. Truck had been sitting up for 6 years so there was corrosion everywhere! Thanks any way!!!!
Old 05-13-2010, 01:27 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
That's good news !
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
