Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-11-2010, 05:05 PM
duaneob1 duaneob1 is offline
sputtering and coughing
first id like to say hello to everyone and that i am new to this forum, that being said i am having trouble with my 1999 aurora, it starts hard but idles smooth if i accelerat it misses bad, if i am at a light and try to take off quickly it "coughs" and sputters i replaced all the plugs and wires and ran a diagnostics on it and i am getting a tcc solenoid reading not sure what to do next, read up on the tcc and it is not showing any of the symptoms that i hear described there, im at a loss and any advice would ve helpfull
Old 05-17-2010, 12:01 AM
peeweewasblue peeweewasblue is offline
Re: sputtering and coughing
I have heard people say that what you are describing can be caused by the 2 crank position sensors and or cam position sensor. Much past that you would have to put it on a real shop computer to find out what is going wrong. Some shops don't charge to much to diagnose it for you.
Old 03-08-2011, 10:38 PM
atomic dervish atomic dervish is offline
sounds like a plugged fuel filter. If it's plugged for too long, it will likely take your fuel pump down. Also, the fuel pressure regulator may be bad. I guess it's fairly common for the fpr to go bad on these machines.
Old 04-11-2011, 12:18 PM
Tony022 Tony022 is offline
My 85 does a similar thingy. Sputters hesitates, then after a while its ok.
Where are the crankshaft sensors located?
I think i can check out or fix most minor problems, except I have the darness time finding the location of different parts.
Old 04-12-2011, 12:38 AM
Crank posisition sensors are down by the oil filter. One comes out no problem, the other is blocked by the AC line. The cam sensor is really easy to get to. Passanger side, rear head. (See attached drawings)
Also I recently started having the hard starting problem. I pulled the vacuum line off of the fuel pressure regulator and it was wet with fuel. Got a new one from the parts store and no more problems.
Word to the wise, depressurize the fuel system before changing the regulator.
Old 10-11-2011, 11:27 PM
kensan99 kensan99 is offline
check your gas tank for water and contammanents
Old 10-26-2011, 11:32 AM
Where is the fuel filter located??
Old 11-04-2011, 12:09 AM
If I remember correctly it is under the car, drivers side, near back seat area. It is threaded on one side and a plastic clip on the other. Oh ya don't forget to depressurize the system before disconnecting. Fuel spray sucks !!!!!!!!!!!!
