Old 05-11-2010, 12:05 AM
pithi69 pithi69 is offline
Rear disc conversion Q
I gots an 90 civic and i'm wondering if I get rear trailing arm assembly off an ABS model will it still work for my non-abs civic? Also will the m/c work? I know the prop valve won't...
Old 05-18-2010, 03:36 AM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Re: Rear disc conversion Q
would'nt that have to do w/ the caliper? I think the trailing arm might be the same on ABS & NONABS alike. get a proportioning valve (cant remember what #).
Old 06-24-2010, 12:35 AM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
the abs trailing arms are no different youll just have to un bolt the snesors you wont need and cant really use. youll also need the 40/40 prop valve for better and equal brakeing. you can do with out it but its not recommended as it causes wrong braking proportions.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
