Old 05-10-2010, 03:23 PM
dijay dijay is offline
Ford windstar van won't start
We have a 2000 Ford Windstar Van.. My husband disconnected battery for winter as we weren't going to use it and was told by ford that there was a problem with cruise control switch catching fire... When he tried to start in spring it won't fire. It has lots of spark. He has changed fuel pump but still won't start. It flashes theft in the information center. And check engine light is on.. What can we do to get this van to start besides taking it to a shop..
Old 05-10-2010, 03:55 PM
mundy5 mundy5 is offline
Re: Ford windstar van won't start
did you recharge the battery? that is step one.
step 2, get a hold of a obdII reader that tells you the codes.
then post them here.
2003 Windstar LX
1998 4dr Civic LX
catvents catvents is offline
Is the engine crank when you turn the key to start? When you you set the key to on ( without cranking the engine) you should hear the "hum noise" of the fuel pump in the tank for a few seconds. If you do not hear it you should look at the fuel pump relay, located in the battery junction box ( engine compartment close to the battery) I understand that you have replaced the fuel pump however if this relay fail ( which is a regular issue on this model) the pump will never work and engine will not fire.
Let us know
2001 Windstar
2007 Pontiac G5
2004 Freestar
1999 Ranger
Old 05-10-2010, 09:40 PM
My husband has recharged battery and put an OBD11 code reader on the van. It says NO CODES after it scans. Very frustrating....
Old 05-10-2010, 09:52 PM
Yes the engine cranks over when we turn key on but does not fire. It has lots of gas coming out of fuel rail when my husband opens up the valve. With the old fuel pump there was very little coming out. My husband is checking out the fuel pump relay.. Hopefully it will be that. Thankyou for your advice.
Old 05-10-2010, 10:22 PM
Selectron Selectron is offline
I wonder if the anti-theft system isn't recognising that particular key? If you have another key, I'd try using that one instead.
If it still doesn't start then I'd give the electronics systems a reset by disconnecting the battery negative terminal for five minutes, then reconnect it and try again.
Old 06-02-2010, 10:48 PM
Re: Ford windstar van won't start theft light blinking
We are still trying to get our 2000 Ford windstar to start.. The theft light is blinking and we think it might be why it isn't starting.. My husband has changed the fuel pump, fuel relay switch and spark plugs and it still won't start. We've tried undoing the negative cable and also the extra key and still won't start.. Turns over good. But won't start.
Can anyone suggest something else we might try?
Old 06-03-2010, 12:52 AM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Are you able to smell raw fuel at the tail pipe when cranking? Have you checked all fuses to make sure none are blown? Other than that and making sure theres power to the ignition coil, cam sensor and crank sensor, thats all I can think of at the moment!
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 06-07-2010, 09:14 PM
Joe Riot Joe Riot is offline
I'm having the same problem with my in-laws van it has fire gas but will not start. I also think it has something to do with the blinking theft light. Does anyone know how to disable it to see if it helps? If not then the only other thing I can think of is the timing must have jump. With fire and gas thats the only other thing it needs is compression and timing? Help me help them! Also its a 2000 ford windstar like above with 3.8L with new battery plenty of spark and plenty of pressure on fuel rail.
Old 06-07-2010, 09:44 PM
usstitanic usstitanic is offline
Your old battery may be weak. Try jump start it. That was what happened to my 2000 Windstar. New battery solved the problem.
Old 06-07-2010, 09:49 PM
If your old battery is weak, recharge will not help. Try jump start it. That was what happened to my 2000 Windstar. New battery solved the problem.
Old 06-08-2010, 10:26 AM
I have a new battery still the same! The in-laws or out-laws need this fixed so I don't have to keep lending my ride....lol To Be Sure someone has ran acrossed this before? Thanks in advance for any help!
Old 06-08-2010, 12:37 PM
My new battery lasted one night. In the morning I had to jump start my van and took the battery back for exchange.
Give jump start a try. If it does not work, then focus on something else.
Old 06-09-2010, 01:11 PM
We finally have our van fixed. We broke down and had it towed to our local Ford dealer. They had it there for 6 days... They had a mechanic work on it on Saturday but he got nowheres with it.. He couldn't even make their own computer machines work to cut a key properly for it... So on Tuesday they put their head mechanic on it and he fixed it... It was all to do with the keys and computer... The computer wasn't recognizing the keys.. They cut a new key and rebooted the computer and now it works perfectly... The key cost 28.00. labour 282.00 and tax... Now 400.00 later I have a smiling husband again.... It sure had my husband frustrated as he tried everything to get it to go...
Hope this helps you out.
