Old 05-10-2010, 01:01 PM
kozmicgirl kozmicgirl is offline
Lights
Hello would code P0410 make your check service engine soon light and ABS light and the brake light, traction off light stay on all the time.
Old 05-10-2010, 02:11 PM
Lights
This is addition to the question i asked would the traction control, brake, ABS lights be one problem and the P0410 code be another so in other words would the secondary air injection malfunction make all the other lights stay on or be the one big problem or two problem. Thank for all the help i can get because times or tight and i don't have money to waste on parts that want solve my promblem.
Old 05-10-2010, 03:18 PM
claimed4all claimed4all is offline
Re: Lights
I recently had the Check Engine, ABS, Brake, and Traction Control lights all come on. Very strange I thought. I took it to a dealer ship, they plugged it into a computer that reads alot more than just a code and they fixed the problem for 65$. It was a loose connection at one of my computers. If all of the lights came on at the same time, it could very well be something similar.
Old 05-11-2010, 02:09 PM
jrecken jrecken is offline
Re: Lights
The lights should say "check vehicle" not engine.
That would indicate that one of the sensors at the wheel is bad or has a bad connection or your hub bearing is bad. Take your car to a shop that has the right diagnostic equipment to check ABS brakes and they should be able to pin point the problem. I had the same problem with a Century and all they had to do was clean the contacts.
good luck
Old 05-11-2010, 11:15 PM
Re: Lights
Thank you very much so it's not the air pump?
Old 05-11-2010, 11:18 PM
Re: Lights
Plus the check tire pressure stay on.
Old 05-12-2010, 01:07 AM
Battery
Hello were is the battery located and how do you get to it. could any body tell where would the low tire pressure battery be located.
Old 05-12-2010, 07:04 AM
Re: Lights
Have you reset the tire pressure light after making sure all of the tires are at the correct pressure? Hold the reset button for about 5 seconds.
Old 05-12-2010, 07:07 AM
Re: Battery
Battery is under the rear seat. Lift the back of the seat on the bottom cushion and it should pop right off. There is no low tire pressure battery... You need to reset your tire pressure the the DriversInformationCenter. Hold the reset button for about 5 seconds.
Old 05-20-2010, 11:42 AM
Re: check tire pressure
Yes i have checked all the tires even the spare and put the proper amount of air and reset it but it still stay on and would a full size tire fit in the trunk hole where the little spare seat.
Old 05-20-2010, 02:47 PM
Trunk is made for the mini not a full size. Did you press and hold the reset button until it said tire pressure reset? You have to hold it for about 5-8 seconds.
