Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 05-10-2010, 09:44 AM
cruiser69 cruiser69 is offline
Tighten Gas Cap
I have 06 Impala LTZ with the 3.9L and 41k on it. I keep getting the tighten gas cap message. I bought a new cap to replace old one and it is very tight. Is there another reason why I would still be getting this message.
Old 05-10-2010, 12:32 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Tighten Gas Cap
Either the gas cap you bought is bad or there is another large EVAP leak somewhere else.
Old 05-10-2010, 03:24 PM
Re: Tighten Gas Cap
I do not see anything wrong with the gas cap. Where else can you get a leak on these.
Old 05-11-2010, 10:38 AM
Airjer_'s Avatar
Re: Tighten Gas Cap
The Evap system includes the fuel tank, charcoal canister, vent solenoid, purge solenoid, and a bunch of hoses and lines.
Check the canister vent fuse in the instrument panel fuse block. If it is blown replace the vent solenoid and the fuse. It is possible that the vent solenoid is bad without the fuse being blown as well. You can test the solenoid by removing it from the vehicle, applying 12 volts to one pin and ground to the other. You should hear it click when you apply power. With power applied you should not be able to blow through it.
Old 05-12-2010, 02:22 PM
Re: Tighten Gas Cap
Thanks for the help. I replaced the vent solenoid and everything is good now. The check engine light cleared itself and no more tighten gas cap message.
Old 05-12-2010, 08:08 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Re: Tighten Gas Cap
Thanks for posting back with the outcome... hopefully this will help someone else with the same problem.
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
