Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-09-2010, 05:38 PM
camaropair camaropair is offline
replacing driver interior door handle
How to remove driver side interior door handle on 96 GMC sierra 1500 pickup?
Old 05-18-2010, 07:54 AM
ken_man_1 ken_man_1 is offline
Re: replacing driver interior door handle
Pull the 2 screws from the door handle, and remove the window crank (if it's manual windows). Then, just pull the interior door panel off. They have plastic pegs that hold it in place. Once the panel is off, you should see the door handle is pretty easy to get to. If it's original, there will be a rivet holding it on. Drill it out, then the handle assy slides a short distance then comes out. It's notched, so it only moves like 2 inches. Pull it out slightly, and then remove the rods off of the handle.
Install is reverse of removal. Most people just use a screw to hold the new handle in place.
Good luck!!
