Old 05-09-2010, 05:19 AM
carl1959 carl1959 is offline
Starter just clicks how to get to it?
Hi Have a British rhd, 2.5 1995 cheerokee ltd 4wd which just clicks when trying to start assume starter motor problem or cables to it but looks a nightmare to get to the motorksny advise on how to get access or advise on why just clicks, battery is fully charged.
Thanks
Old 05-09-2010, 08:47 AM
inafogg inafogg is offline
Re: Starter just clicks how to get to it?
you can try hitting the starter if you dont have enough room use a long extension
or simular to tap/hit starter but you need to check for 12v at solonoid.
battery connections clean/tight.Good Luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 05-09-2010, 09:03 AM
Will give it a hit could be stuck solonoide or pinnion but feel that I need to get the starter off and check on the bench need input from anyone whom has removed one befor, is it best to access from top of engine removing manifolds or from below removing anything that is in the way not worked on these cars befor and was given the car, Many thanks for the advise have a great day. Carl
Old 05-09-2010, 09:05 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Carl, Welcome to AF. It should be easier to access the starter from below.
You may also want to check, the positive battery cable, there have been a few that were corroded inside the insulation, as far as 10cm from the battery. Reduced voltage could cause your problem.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-09-2010, 09:40 AM
Hi Fred, Thanks for the advise will check the cable as well as the starter now will attack from the underneath,
Carl
