Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 05-08-2010, 05:32 PM
sir kingsley sir kingsley is offline
Turn signal snap back broken
Hello, I have a 96 TS with a semi-broken turn signal. The auto-snap back works for right turns, but not left turns. I thought it might be a burned out turn signal light, so I replaced the one on the driver's side front, which didn't change anything. I then noticed that the top 2 bulbs on each of the rear brake lights/turn signals were burned out. These are the two small bulbs. When I replaced one of these with a new bulb, it wouldn't work. I'm wondering if the burned out bulbs could be affecting the turn signal, and also why all of these rear top bulbs are burned out. I'm skeptical that the bulbs are affecting the signal, since they are burned out on the right side and the right turn signal will auto return. Any ideas of what's going on here? I checked the fuses and they're all OK.
Old 05-09-2010, 12:45 AM
LMP's Avatar
LMP LMP is offline
Re: Turn signal snap back broken
The snap action auto hold or auto return is purely mechanical and depends on plastic tabs....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 05-12-2010, 05:38 PM
nicke66 nicke66 is offline
Do you know how to fix it? Is there spare parts available to resonable prices?
Old 05-15-2010, 07:38 PM
jarl jarl is offline
Plastic parts, and some spings prone to metal fatigue and failure. Less than $3 at O'Reillys.
As for the instructions: http://www.thingsthatgo.ca/forum/vie...php?f=11&p=189
'94 Trans Sport 3800
