Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 05-08-2010, 12:51 PM
Heater Core Heater Core is offline
Hearbeat Hum
Can't explain it any other way. Ya know how a normal engine just purrs along? Well now it sounds like a humming that beats like a heart beat. In Park and more so at 50-60 miles an hour and more intense going up steep hills.
Anyone know what might be causing this?
Of Note: I have another post "Only starts in Neutral" just before this one about the same vehicle, 1994 Olds Bravada, only starting in Neutral. I say this in case these two items might be related.
This is also posted as "groaning/humming noise" but I don't know how to delete them to make just one. Sorry. Anyway:
The exhaust gas pressure "puffs" to the heartbeat at the tailpipe?". Aside from the very loud deep slow heartbeat humming which is actually intermittent (when passing thru gears), when it is not "humming" it actually sounds like a constant loud deep version of a lifter knocking/ticking (inside the tailpipe as I said). I used the video on my camera to try to capture the sound but it can't be heard on camera audio (the ticking can but not the hum). Weird, considering how loud it is. I don't see where a video can be posted here anyway.
Old 05-08-2010, 07:31 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Hearbeat Hum
Does the humming change or can you feel it in the steering wheel while in a gentle curve?
Old 05-09-2010, 02:49 PM
Re: Hearbeat Hum
No, you can't feel it. Just hear it. It gets slightly louder on big inclines; going up mountain sides (on highway). Faintly in Park and sometimes not in Park.
Old 05-09-2010, 07:02 PM
AF - Advisor
Re: Hearbeat Hum
Easiest first,
If all the tires were installed at the same time, make sure you have 32 psi front and 30 psi rear.
While it's in "heartbeat mode", downshift to Drive which will cause the engine to speed up....does the heartbeat change?
You following this Eric?
Old 05-09-2010, 08:24 PM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
Re: Hearbeat Hum
^ Chris, my '93 Bravada says 35 PSI all the way around...
1993 Olds Bravada 4.3L CPI
1999 GMC Safari SLE AWD
2002 Chevy Astro LT AWD
Old 05-10-2010, 01:36 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: Hearbeat Hum
check your motor mounts, Chris had a quick way to check those visually if he can post it again. Other than that check the belt, pulleys, power steering pump and compressor.
Old 05-10-2010, 06:41 PM
AF - Advisor
Re: Hearbeat Hum
My rear tires wear out the middle too quick if they're set the same as the front LeeAnn94astro...probably the heat and humidity down here.
Like Eric says,
To check the motor mounts, raise the hood, start the engine, apply enough brake pedal to hold your Bravada in place, put the gear selector in Drive, lightly apply throttle and look between the lower hood and cowl at the engine.
If you see it rock over more than a coupla inches, the driver's side motor mount is broken.
If it rocks over more than a coupla inches while the transmission is in reverse, the passenger side motor mount is broken.
Old 05-18-2010, 07:55 PM
Re: Hearbeat Hum
I haven't had time til now to listen again. The heartbeat hum is actually coming out of the TAILPIPE. Yes, the tailpipe. I put my ear to it and it is actually coming from the tailpipe.
Vewy vewy intwesting. What ya think a that?
Old 05-19-2010, 06:34 PM
AF - Advisor
Re: Hearbeat Hum
Does the exhaust gas pressure "puff" to the heartbeat at the tailpipe?
Old 05-20-2010, 12:41 PM
Re: Hearbeat Hum
Yes it "puffs". Aside from the very loud deep slow heartbeat humming which is actually intermittent (when passing thru gears), when it is not "humming" it actually sounds like a constant loud deep version of a lifter knocking/ticking (inside the tailpipe as I said). I used the video on my camera to try to capture the sound but it can't be heard on camera audio (the ticking can but not the hum). Weird, considering how loud it is. I don't see where a video can be posted here anyway.
Old 05-20-2010, 06:42 PM
AF - Advisor
Re: Hearbeat Hum
My pics and videos are on Photobucket.com then I just post a link to there.
How'bout Tony DePillo's SS/B Honkin' Hemi ...
Old 05-20-2010, 06:52 PM
AF - Advisor
Re: Hearbeat Hum
Almost sounds like a possible leaky exhaust valve.
Anybody remember how to diagnose a leaky valve with a vacuum gauge?
Old 05-21-2010, 12:32 AM
PatrickinWA PatrickinWA is offline
Thumbs up Re: Hearbeat Hum
Just got a 97 bravada a few days ago and it was doing something similar. Just changed all the plugs and wires and it purrs like a kitten now. Looked like some one only did 5/6 plugs last time. Middle one on drivers side is a pain in the ass to even get the socket onto. I'll see if that fixs the cold start problem tomorrow. My sisters car had the only starts in neutral thing a while back. Neutral position sensor/switch was the problem and fix.
Old 05-21-2010, 06:18 PM
AF - Advisor
Re: Hearbeat Hum
Thanks for the info and welcome to the site PatrickinWA!!!
Old 05-21-2010, 08:18 PM
Re: Hearbeat Hum
Thought about this a little more today and thought I would mention the catalytic converter as a suspect since you said it gets worse on an incline. When they go bad the rust and whatever collects inside tends to just roam around in there so exhaust pressure builds up a little until it can push through.
